Create an instance AxTChart in my worker thread
PS Soluções
Post by PS Soluções » Thu Jul 16, 2009 9:01 pm
I would like to create an instance o AxTChart inside my class (I'm working with C#), setup some plots, get an image. The problem is that this function is inside a method being executed in a worker thread and there is no Form associated with it.
When I do "new AxTChart()" I get an thread exception that says that I "cannot create an instance of the ActiveX control because the current segment is not in an STA (single-threaded apartment)".
What should I do?
Re: Create an instance AxTChart in my worker thread
Post by Marc » Mon Jul 20, 2009 9:22 am
I don't have any example project setup to check this but it seems that the thread will probably need to be created as single thread.
eg.
using System;
using System.Threading;
namespace testapp
   class Class1
      static void Main(string[] args)
       Thread.CurrentThread.ApartmentState =
          ApartmentState.STA;
If that doesn't give you the results you require and you have a small sample application you can send us we'll take a look.
