I need to draw tens of thousands points on TChart. I tried with 5000 and 50000 points.
I attached sample project with TChart and GridSplitter. By moving the splitter I noticed very large delay which is not acceptable.
Is there any way to draw such a large number of points in SilverLight ?
Regards.
SilverLight: Large sets of data (50000 points)
- SilverlightApplication1.rar
- (1.2 KiB) Downloaded 442 times
Re: SilverLight: 50000 points - very slow.
Hi jarp,
I'm sorry but I'm not able to build an application with the files you sent. Can you please send a simple example project we can run "as-is" to reproduce the problem here?
Re: SilverLight: Large sets of data (50000 points)
Hi jarp,
Thanks for the project!
First of all, notice that important performance enhancements have been implemented in TeeChart.Silverlight.dll for next maintenance release, due out in about 2 weeks.
Anyway, it's possible enhancing your application's performance using FastLine’s DrawAllPoints property set to false or DownSampling function. You’ll find examples of those features at the sections below in the features demo, available at TeeChart’s program group.
All Features\Welcome !\Chart styles\Standard\Fast Line\Fast Line Speed DrawAll
All Features\Welcome !\Functions\Extended\Reducing number of points
Adding DrawAllPoints=false to your code, as shown below, highly increases application's performance.
Hope this helps!
public MainPage()
Chart1.Series.Add(new Steema.TeeChart.Silverlight.Styles.FastLine());
//((Steema.TeeChart.Silverlight.Styles.Points)Chart1.Series[0]).Pointer.Style = Steema.TeeChart.Silverlight.Styles.PointerStyles.SmallDot;
Chart1.Series[0].FillSampleValues(50000);
(Chart1[0] as Steema.TeeChart.Silverlight.Styles.FastLine).DrawAllPoints = false;
Actually I need to draw Points series not the Line. I tried with downsampling tool but it doesn't seem to work.
Are the performance enhancements implemended in next release will cope with a large number of points ?
Steema.TeeChart.Silverlight.Styles.Points points = new Steema.TeeChart.Silverlight.Styles.Points();
points.Pointer.Style = Steema.TeeChart.Silverlight.Styles.PointerStyles.SmallDot;
points.FillSampleValues(50000);
Chart1.Series.Add(points);
Steema.TeeChart.Silverlight.Functions.DownSampling downsampling1 = new Steema.TeeChart.Silverlight.Functions.DownSampling();
downsampling1.Tolerance = 100.0;
downsampling1.Method = Steema.TeeChart.Silverlight.Functions.DownSamplingMethod.Average;
points.Function = downsampling1;
Hi jarp,
What about doing as in the code snippet below? It works pretty well for me here.
public MainPage()
Chart1.Series.Add(new Steema.TeeChart.Silverlight.Styles.Points());
Chart1.Aspect.View3D = false;
Steema.TeeChart.Silverlight.Functions.DownSampling downSampling1 = new Steema.TeeChart.Silverlight.Functions.DownSampling(Chart1.Chart);
Steema.TeeChart.Silverlight.Styles.Points points1 = new Steema.TeeChart.Silverlight.Styles.Points(Chart1.Chart);
points1.DataSource = Chart1[0];
downSampling1.Tolerance = 10.0;
downSampling1.Method = Steema.TeeChart.Silverlight.Functions.DownSamplingMethod.Average;
downSampling1.DisplayedPointCount = Chart1[0].Count / (int)downSampling1.Tolerance;
points1.Function = downSampling1;
Chart1[0].Active = false;
Chart1[0].ShowInLegend = false;
