Fill Peaks of sine wave
asupriya
Post by asupriya » Thu Sep 24, 2009 3:24 am
I have an array of fastline series which display some sine waves. I like to know how i can optionally (user triggered) fill the peaks and through of the fastline series's sine wave.
Any help in this regard is greatly appreciated.
Re: Fill Peaks of sine wave
Post by Yeray » Thu Sep 24, 2009 11:53 am
Hi asupriya,
I'm not sure to understand what are you exactly trying to draw here. Maybe a picture would help us to understand it better.
Anyway, have you seen the SeriesBand Tool and the SeriesRegion Tool?
- SeriesBandTool (All Features\Welcome !\Tools\SeriesBand Tool). Giving a line series to it, the are under the line until zero, will be painted.
- SeriesRegionTool (All Features\Welcome !\Tools\Area under the curve). With this, you'll be able to paint the area under a line but here you'll be able to set an XValue to start painting (the peak begin), an XValue to end painting (the peak finish) and an YValue (origin) to limit the drawing area under the line.
asupriya
Post by asupriya » Thu Sep 24, 2009 12:34 pm
I am looking for something of effect shown in the image attached.
Post by Yeray » Thu Sep 24, 2009 2:57 pm
Hi asupriya,
If you have those sin waves horizontal, you'll be able to use SeriesRegionTool. Note that you should create a SeriesRegionTool for each zone to mark.
And note that I've added the possibility to use this tool with Horizontal Line series in the wish list to be implemented in a further release (TF02014442).
asupriya
Post by asupriya » Sat Sep 26, 2009 2:30 am
SeriesBandTool, SeriesRegionTool are not the ones i am looking for. Is there anything that can draw as shown in the attached image?
Post by Yeray » Mon Sep 28, 2009 12:12 pm
Hi asupriya,
You can use SeriesRegionTool to obtain a chart like in your picture with the following code:
            int nSeries = 4;
            int [] YPos = new int[nSeries];
            Steema.TeeChart.Styles.FastLine[] fast = new Steema.TeeChart.Styles.FastLine[nSeries];
            Steema.TeeChart.Tools.SeriesRegionTool[] region = new Steema.TeeChart.Tools.SeriesRegionTool[nSeries];
            for (int i = 0; i < nSeries; i++)
                YPos[i] = i * 5;
                fast[i] = new Steema.TeeChart.Styles.FastLine(tChart1.Chart);
                if (i % 2 == 0)
                    for (int j = 0; j < 200; j++) fast[i].Add(Math.Sin((double)j / 10) + YPos[i]);
                    for (int j = 0; j < 200; j++) fast[i].Add(Math.Cos((double)j / 10) + YPos[i]);
                region[i] = new Steema.TeeChart.Tools.SeriesRegionTool(tChart1.Chart);
                region[i].Series = fast[i];
                region[i].Origin = YPos[i];
                region[i].UseOrigin = true;
                region[i].Brush.Style = System.Drawing.Drawing2D.HatchStyle.Vertical;
                region[i].Brush.Transparency = 100;
                region[i].Pen.Visible = false;
                region[i].Brush.ForegroundColor = fast[i].Color;
asupriya
Post by asupriya » Mon Sep 28, 2009 6:41 pm
Great. Thanks alot. This is exactly what I needed.
Appreciate your help.
