legen symbol pen width
Sean Murphy
Post by Sean Murphy » Mon Oct 12, 2009 1:15 pm
Tchart Pro vsn 8.06
Chart with a few Tlineseries drawing X,Y graphs
I have lineseries.pointer.size = 1, lineseries.pointer.visible=false
so the graph draws just a linebetween the x,y points, the actual points not being displayed on chart
If I alter lineseries.pen.width it alters thw width of the line connecting the x,y points, which is the effect I want.
However, I have the legend set to show each lineseries so there is a checkbox, the series name, and between the checkbox and series name there
is a short line the same colour as the series colour configured. This is default Tchart display, I'm not using custom draw for legend.
When I alter lineseries.pen.width it also alters the width of the line that is shown in the legend, my question is can I prevent this?
I want legend line width to be fixed at 3, but user to be able to set grap line width to different settings
thanks
Sean
Re: legen symbol pen width
Post by Yeray » Wed Oct 14, 2009 10:36 am
Hi Sean,
I'm afraid that the pens drawn in the legend symbols are linked to the series, so there isn't an option to change them. However, you can use the legend's symbol's event OnDraw to customize them. Something similar to the demo at All Features/Welcome !/Miscellaneous/Legend/Symbol OnDraw
uses series, TeCanvas;
var i: Integer;
  Chart1.View3D := false;
  for i:=0 to 4 do
    Chart1.AddSeries(TLineSeries.Create(self));
    Chart1[i].FillSampleValues();
  Chart1.Legend.Symbol.OnDraw:=LegendDraw;
procedure TForm1.LegendDraw(Sender: TObject; Series: TChartSeries;
  ValueIndex: Integer; R: TRect);
var YPos: Integer;
  with Chart1.Canvas do
    if Chart1.Legend.Symbol.Pen.Visible then
      //clear the symbol
      Brush.Style:=bsSolid;
      Pen.Style:=psClear;
      Rectangle(R,0);
      //draw the new symbol
      Pen.Style:=psSolid;
      Pen.Color:=Series.Color;
      Pen.Width:=3;
      YPos:=(R.Bottom-R.Top) div 2 + R.Top;
      Line(R.Left,YPos,R.Right,YPos);
Sean Murphy
Post by Sean Murphy » Fri Oct 16, 2009 6:26 am
thanks Yeray, I'll try that way.
Sean
