Tool Data Table
Calou
Tool Data Table
Post by Calou » Tue Oct 13, 2009 8:53 am
I have problem with DataTable
Here are the pictures:
http://www.cijoint.fr/cjlink.php?file=c ... th66PH.jpg
http://www.cijoint.fr/cjlink.php?file=c ... DXAunS.jpg
With the datatable there is no mars month.
I don't understand why :oops:
Thanks for help
Re: Tool Data Table
Post by Narcís » Tue Oct 13, 2009 2:36 pm
Hi Calou,
I could reproduce this one. Basically TDataTableTool requires more space to plot than axes labels and this issue depends on chart's width. I've added your request to the wish-list to be enhanced for future releases (TV52014476).
Calou
Re: Tool Data Table
Post by Calou » Fri Nov 20, 2009 1:45 pm
Do you know when the update version of Tchar will include this modification?
Re: Tool Data Table
Post by Yeray » Fri Nov 20, 2009 3:38 pm
Hi Calou,
I'm afraid that I can't tell you a date for this to be enhanced right now. It probably involves all the labels calculations.
Note that deactivating the tool and resizing the form to be smaller, there is a point where some axes labels are also hidden to avoid overlapping. The difference with the datatable tool active is that an extra margin is added at the left side to draw the series titles in the tool.
While it isn't enhanced, you could remove this margin:
if ChartTool1.Active then
    Chart1.MarginLeft:=0;
Or also you could restrict the chart size as in the following example:
uses DateUtils;
procedure TForm4.FormCreate(Sender: TObject);
var i: Integer;
    dt: TDateTime;
    tmp: String;
  Series1.XValues.DateTime:=true;
  Chart1.Axes.Bottom.DateTimeFormat:='mmm yy';
  for i := 1 to 12 do
    dt:=EncodeDate(2009, i, 1);
    DateTimeToString(tmp, 'mmm yy', dt);
    Series1.AddXY(dt, random, tmp);
    Series2.AddXY(dt, random);
  Chart1.MarginUnits:=muPixels;
procedure TForm4.FormResize(Sender: TObject);
var i, tmpWidth: Integer;
  tmpWidth:=Chart1.Canvas.TextWidth(Chart1[0].Name);
  for i:=0 to Chart1[0].Count-1 do
    tmpWidth:=tmpWidth+Chart1.Canvas.TextWidth(Chart1[0].Labels[i]);
    tmpWidth:=tmpWidth+Chart1.MarginLeft+Chart1.MarginRight+Chart1[0].Count*15;
  if (tmpWidth > Form4.Width) then
    Chart1.Align:=alNone;
    Chart1.Width:=tmpWidth;
  end
    Chart1.Align:=alClient;
