3D stacked bar problem
Vic
Post by Vic » Mon Jul 12, 2004 2:06 am
Hi, i found that there is a problem on drawing 3D stacked bar. Is there any workaround for fixing this problem? I found a similar post on http://www.teechart.net/support/modules ... 98fc228339.
My TeeChart Version is TeeChart for .Net v1
Post by Pep » Mon Jul 12, 2004 8:41 am
this problem has not been fixed. We'll try to fix it for the next maintenance releases. In meantime you can use the workaround we suggest in the post you have seen.
