ColorRange Function
e-ssentia
ColorRange Function
Post by e-ssentia » Fri Jan 08, 2010 9:44 am
Dear sirs,
i have a problem with TeeChart for .NET.
With an older version of the library (7.07 for Delphi) there was a function named "ColorRange" that allowed the user to change the color of a range of points for a graphic series.
Now, with my version of teechart for .NET, i cannot find the ColorRange function; there's some equivalent method?
In other words, How can I change the color for a range of points value in my graphic (...without rebuild the graph adding every point with his own color)?
Re: ColorRange Function
Post by Narcís » Fri Jan 08, 2010 2:47 pm
Hi e-ssentia,
This was in 3D series like: Surface, ColorGrid, Contour, etc.; for example:
http://www.teechart.net/support/viewtop ... nge#p13876
Wasn't it? Same properties and behaviour applies to TeeChart for .NET.
Hope this helps!
e-ssentia
Post by e-ssentia » Sat Jan 09, 2010 1:49 pm
Thanks Narcís for the reply.
The problem is that I don't use a 3D series. In my chart I use a line serie, and in my old Delphi application I used the following function:
tChart1.Series[0].ColorRange(ValueList, FromValue, ToValue, Color);
So I need to know how can obtain the same result with the version for .NET (if it's possible).
Post by Yeray » Mon Jan 11, 2010 10:00 am
Hi e-ssentia,
I've added this to the wish list to be implemented in future releases (TF02014632). In the meanwhile you could create your own function that would probably be very similar to the function that will be added to the sources as soon as possible:
        private void ColorRange(Steema.TeeChart.Styles.Series ASeries, Steema.TeeChart.Styles.ValueList AValueList, double FromValue, double ToValue, Color AColor)
            double tmpValue;
            for (int t = 0; t < AValueList.Count; t++)
                tmpValue = AValueList.Value[t];
                if ((tmpValue >= FromValue) && (tmpValue <= ToValue) && (!ASeries.IsNull(t)))
                    ASeries.Colors[t] = AColor;
            tChart1.Refresh();
e-ssentia
Post by e-ssentia » Mon Jan 11, 2010 2:35 pm
Thanks Yeray, your function works!!! :wink:
