TeeChart Cursor Tool
rsites
Post by rsites » Thu Jan 28, 2010 7:15 pm
Is there a way to read the position of the Cursor Tool as it is moved across the chart? I would like to have two vertical cursors and read the X-Axis position of each of these cursors.
Re: TeeChart Cursor Tool
Post by Yeray » Fri Jan 29, 2010 9:11 am
Hi rsites,
You should use TCursorTool OnChange event:
procedure TForm1.ChartTool1Change(Sender: TCursorTool; x, y: Integer;
  const XValue, YValue: Double; Series: TChartSeries; ValueIndex: Integer);
  Caption:='X: '+IntToStr(x)+' Y: '+IntToStr(y);
rsites
Post by rsites » Fri Jan 29, 2010 1:16 pm
Thanks. Works great.
