Axis with no associated serie
Roman
Post by Roman » Fri Jul 16, 2004 6:19 am
I have following problem: all my series have their own custom Y axes, bottom axis is DateTime and right axis in not with any serie. I'd like to use right axis as a ruler (vertical line), which can user drag across the chart (some extra code will get the values of all series) and read the particular values. But when I add first serie, right axis is invisible :( .
How to make this axis to be still visible?
Thanx
Post by Pep » Fri Jul 16, 2004 6:28 am
Hi Roman,
the axis should be asociated with any Series. A trick could be to create a fake series, and make it invisible.
