SeriesBand tool for vertical custom axises
Avijit
Post by Avijit » Fri Mar 26, 2010 4:00 pm
Can you help me use the SeriesBandTool for custom axises?
I have 4 data series and out of these 4 Line serieses i want to create 2 SeriesBand tool.
I have created two custom vertical axis and the Pixel Position of each of the custom axis is as below -
Custom Vert Axis 1 :
StartPosition = 0
EndPosition = ChartHeight/2 + some offset
Custom Vert Axis 2 :
StartPosition = EndPosition of Custom Vert Axis 1 + some offset
EndPosition = ChartHeight;
I have associated the first 2 Line serieses with Custom Vert Axis 1 and the last two with Custom Vert Axis 2.
Then i am creating SeriesBandTool 1 with the first two serieses and SeriesBandTool 2 with last two serieses.
My expectation was - the two series band tool will not overlap with each other. But the series bands are fully overlapping.
To my understanding - i think both the SeriesBand tool is getting drawn irrespective of the Custom axis positions. I may be wrong here.
Please let me know how can i solve that problem.
Avijit
Avijit
Re: SeriesBand tool for vertical custom axises
Post by Avijit » Mon Mar 29, 2010 9:23 am
I have solved that issue...
-Avijit
Post by Yeray » Mon Mar 29, 2010 3:33 pm
Hi Avijit,
I'm glad to see that you've solved your problem. Anyway, here is an example that may help other users in the same situation:
            for (int i = 0; i < 4; i++)
                new Steema.TeeChart.Styles.Line(tChart1.Chart);
                tChart1[i].FillSampleValues();
            tChart1.Draw();
            for (int i = 0; i < 2; i++)
                new Steema.TeeChart.Tools.SeriesBandTool(tChart1.Chart);
                (tChart1.Tools[i] as Steema.TeeChart.Tools.SeriesBandTool).Series = tChart1[i*2];
                (tChart1.Tools[i] as Steema.TeeChart.Tools.SeriesBandTool).Series2 = tChart1[(i*2)+1];
                tChart1.Axes.Custom.Add(new Steema.TeeChart.Axis());
                tChart1.Axes.Custom[i].StartPosition = 100/2 * i;
                tChart1.Axes.Custom[i].EndPosition = 100 / 2 * (i + 1);
                tChart1[i * 2].CustomVertAxis = tChart1.Axes.Custom[i];
                tChart1[(i * 2) + 1].CustomVertAxis = tChart1.Axes.Custom[i];
