In VCL V2010 a 3D Pie loaded from a file has a wrong vertical position (too much at bottom). The same chart (with same View3DOptions.VertOffset=24) loaded with VCL V8.06 has the right position. For correct vertical position with v2010 we have to change View3DOptions.VertOffset=-14. We have manny chart configurations saved at our clients which won't be completly visible after update to V2010. Could you please help us?
Bert Kreisel
v2010 View3DOptions.VertOffset changed behavior
- Newbie
Re: v2010 View3DOptions.VertOffset changed behavior
Hi Bert,
Could you please attach a simple example project or a *.tee file we can run "as-is" to reproduce the problem here?
- Newbie
Hi Narcis,
i attached v806.tee in v806.zip.
Bert Kreisel
Bert Kreisel
- v8_06.zip
- (1.81 KiB) Downloaded 275 times
Hi Bert,
We can't load the tee file you've attached above. It gives us a "Class TCopyLastFunction not found" error.
Could you please send us an example we can run as-is here of how to create a tee file like this, or try to send us another tee file without this dependence?
Note that you can export your chart as text so the configuration can be revised with notepad or similar.
- Newbie
i can load the file in TeeChartOffice. Anyway i attached v8_6.tee in v8_6.zip. It's an export as text where I deletet the TCopyLastFunction.
Bert Kreisel
Bert Kreisel
- 8_6.zip
- (1.81 KiB) Downloaded 283 times
Hi Bert,
Thanks for the file. I could reproduce the issue here added it (TV52014892) to the defect list to be investigated.
