Installation Problem of VCL2010 with D7
pest
Post by pest » Fri May 21, 2010 3:32 pm
Hello!
After uninstallating TChart8 and installaing 2010 for Delphi7 there are no Tchart tabs and components in IDE available.
I checked all the Paths and Packages. There are no relicts of old versions.
Finally I tried to uninstall 2010 and install V8 again with the same result...
Can you please help me?
Bye,
Peter
Re: Installation Problem of VCL2010 with D7
Post by Narcís » Fri May 21, 2010 3:39 pm
Hi Peter,
You could try running TeeInstall.exe included with the installer. Then go to Project -> Options -> Packages and check that v9 (v2010) packages are enabled. Go to Project -> Options -> Directories/Conditionals -> Search Path and check that v9's "Bin" and "Lib" folders are on *top* of the list. Finally enable the left-bottom "Default" checkbox.
Hope this helps!
pest
Post by pest » Tue May 25, 2010 6:41 am
Hi Narcís!
That's it! It's working again.
There is only one thing left: the components are disabled by default. Even after activating them in "Project->Options->packages" and checking Default they are gone after Closing Delphi!
Any suggestions?
Thanks a lot!
Peter
Post by Yeray » Tue May 25, 2010 7:31 am
Hi Peter,
Try activating them without any project opened and close the IDE. If this doesn't save the changes, try creating a new application, apply the changes again, save the project, close the IDE and open the project again.
pest
Post by pest » Tue May 25, 2010 7:46 am
Hi Yeray!
Thanks for your help!
Now it works just fine.
Have a nice day.
Peter
Post by Yeray » Tue May 25, 2010 9:05 am
Hi Peter,
I'm glad to hear that!
Have a nice day you too!
