receive data and create chart in real time
ljoli
Post by ljoli » Fri Jul 16, 2010 3:35 pm
----> I would like to build a chart with a CSV file which is update every 100ms.
I began to write the following code :
using System;
using System.Linq;
using System.Text;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using Steema.TeeChart.WPF.Styles;
using Steema.TeeChart.WPF.Tools;
using Steema.TeeChart.WPF.Themes;
using Steema.TeeChart.WPF;
using Steema.TeeChart.WPF.Drawing;
using Steema.TeeChart;
using Steema.TeeChart.WPF.Editors;
using Steema.TeeChart.WPF.Export;
using Steema.TeeChart.WPF.Data;
using Steema.TeeChart.WPF.Functions;
using System.Drawing;
using System.Data;
namespace CSV_real_time
    /// <summary>
    /// Interaction logic for Window1.xaml
    /// </summary>
    public partial class Window1 : Window
        public Window1()
            // disable of view in 3D
            this.tChart1.Aspect.View3D = false;
            //display or not the legend of chart
            this.tChart1.Legend.Visible = false;
            tChart1.AutoRepaint = true;
            // title of chart
            this.tChart1.Header.Text = " CSV file in real time ";
            // new fastline of steema library
            FastLine fast1;
            // add fastline of chart
            fast1 = new Steema.TeeChart.WPF.Styles.FastLine(tChart1.Chart);
            // Path of CSV file
            TextSource textsource1 = new TextSource("C:\\Users\\ljoly\\testone.csv");
            // Decimale Separator of each data
            textsource1.DecimalSeparator = ',';
            // Number of header ( here it is X and Y )
            textsource1.HeaderLines = 2;
            // Separator of each data
            textsource1.Separator = Convert.ToChar("\t");
            // link fastline and data on CSV file
            fast1.DataSource = textsource1;
            // X field data of CSV file
            textsource1.Fields.Add(0, "X");
            // Y field data of CSV file
            textsource1.Fields.Add(1, "Y");
            // Active fastlien serie which come from CSV file
            textsource1.Series.Active = true;
            // link serie of fastline of CSV file
            textsource1.Series = fast1;
            // make a check of datasource
            fast1.CheckDataSource();
And I see an example on the documentation, but it's not really adapt at WPF code.
I use Visual studio 2008 ( WPF code ) with Teechart 3.5.3188.18562
Re: receive data and create chart in real time
Post by Yeray » Mon Jul 19, 2010 7:47 am
Hi ljoli,
I'm not sure to understand what's the exact problem you have with it.
If you have a chart correctly linked to the datasource (it shows the initial data) but it is not refreshing? You could use a timer and call CheckDataSource every timer tick.
ljoli
Post by ljoli » Mon Jul 19, 2010 8:32 am
Hello Yeray,
In fact, I had a chart with my CSV file but it is not refresh like you say.
I see the different class, in WPF there are "timer" class and "DispatcherTimer". But I don't know really how to use it. On the web I found this code
-> http://social.msdn.microsoft.com/forums ... f7099a936/
Do you have an example in WPF with a timer to create an animate chart ?
Like the example of feature of Teechart:
all features->Welcome->Speed->Real-time charting
LJ
ljoli
Post by ljoli » Mon Jul 19, 2010 9:49 am
So, after some search on the web. I found a solution like below :
using System;
using System.Linq;
using System.Text;
using System.Timers;
using System.Windows.Threading;
using System.Data;
    /// <summary>
    /// </summary>
        // Declaration of global variable
        public Steema.TeeChart.WPF.Styles.FastLine fast1;
        //private System.Windows.Threading.DispatcherTimer TimerClock;
        // use the DispatcherTimer class for timer application
        private DispatcherTimer timer;
        public Window1()
            // new instance of DispatcherTimer
            timer = new DispatcherTimer();
            // set interval of timer --> 100 ms
            timer.Interval = TimeSpan.FromSeconds(0.100);
            // Each tick check datsource of my CSV file
            timer.Tick += timer1_Tick;
            //Timer timer = new System.Timers.Timer(1000);
            timer.Start();
            TimerClock = new System.Windows.Threading.DispatcherTimer();
            //Creates a timerClock and enables it
            TimerClock.Interval = new TimeSpan(0,0,1);
            TimerClock.IsEnabled = true;
            // title of chart
            //FastLine fast1;
            // Path of CSV file
           void timer1_Tick(object sender, EventArgs e)
is it like that to make a good real time fastline ?
Post by Sandra » Mon Jul 19, 2010 11:01 am
Hello ljoli,
You're right, if you want use timer in WPF you should use a DispatcherTimer. Could you please say us, if this timer works fine for you and solve your problem?
ljoli
Post by ljoli » Mon Jul 19, 2010 11:04 am
Yes that's works with DispatcherTimer !!
My problem is solved :wink:
Post by Sandra » Mon Jul 19, 2010 11:20 am
Hello ljoli,
Thanks for your information; I am glad that now works fine for you :).
