change the format of the X-axis of time in a number format
Michael
Post by Michael » Fri Jul 30, 2010 8:54 am
new day, new problem ;-)
The X-axis of my charts (TlineSeries , smoothed) as a time axis is defined. This also works well. But if I zoom in, then the label of the X-axis change in the number format and then remains even when zoomed out shall exist.
This small demo program illustrates the situation. Did I forget to set a parameter or is it an error?
I use Delphi 2009 with TeeChart pro v2010.00.00407 Win32.
regards
date_demo.zip
(1.93 KiB) Downloaded 422 times
Michael
Re: change the format of the X-axis of time in a number format
Post by Michael » Mon Aug 02, 2010 8:59 am
Hello, could be traced the problem, or additional information required?
regards
Post by Yeray » Mon Aug 02, 2010 5:36 pm
Hi Michael,
We do our best to provide technical support on this forum board in a timely and efficient fashion. If you are interested in direct e-mail technical support you may be interested in our Pro-Support service.
The Smoothed property is a quite new feature. It creates a Series and a Function internally and I've seen it doesn't support DateTime XValues.
I've added it to the wish list to be implemented asap (TV52015070).
