Drawing ellipses on TMapSeries
James
Post by James » Thu Sep 02, 2010 9:58 am
Hello there,
I would like to draw some ellipses on a TMapSeries. The user should be able to zoom the map as usual and they should stick to the map and zoom as expected.
Do I need to do this using some sort of ownerdraw functionality, or is there a series i can make use of?
I would also like to draw a small arrow on the map, which should not change size with zoom.
Lastly I would eventually like to do this in the .NET version of TeeChart also.
Could somebody point me in the right direction of what i should be doto accomplish this.
Any help much appreciated!
James
Re: Drawing ellipses on TMapSeries
Post by Yeray » Fri Sep 03, 2010 2:32 pm
Hi James,
In VCL you could do something as follows. I'm not sure if that's the behaviour you would like to have. If you want your arrow not to zoom at all you should draw it manually at OnAfterDraw event.
uses TeeWorldSeries, TeeShape, ArrowCha;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TWorldSeries) do
    FillSampleValues();
  with Chart1.AddSeries(TChartShape) as TChartShape do
    Gradient.Visible:=true;
    X0:=-20;
    X1:=0;
    Y0:=-40;
    Y1:=0;
    Transparency:=20;
  with Chart1.AddSeries(TArrowSeries) as TArrowSeries do
    AddArrow(-40, 50, -20, 0);
    ArrowWidth:=10;
    ArrowHeight:=20;
    Pointer.Pen.Width:=2;
In .NET it should be too different. If you find troubles with it, don't hesitate to let us know.
