Bug changing data in the data sheet with null values
acastro
Post by acastro » Tue Sep 14, 2010 2:37 pm
I attached a project example. It load a serie with a null value (transparent color). All ok, but if I open the chart editor and go to the data sheet, and change the value, the value is not updated in the chart, and if I open again the chart editor when I go to the data sheet it gives me an error.
TestTeeChart2010.zip
(33.23 KiB) Downloaded 490 times
Re: Bug changing data in the data sheet with null values
Post by Sandra » Wed Sep 15, 2010 11:30 am
Hello wakeup,
I could reproduce your problem and I have added your request in bug report list with number [TF02015152]. We will try to fix it for next maintenance releases of TeeChart.Net.
Post by Sandra » Thu Sep 16, 2010 11:15 am
Hello wakeup,
I have informed you that we've already fixed this problem (TF02015152). It will be available with the next maintenance release.
acastro
Post by acastro » Thu Sep 16, 2010 11:17 am
Nice!
Thanks!
