Some portion of the line in Top area of chart disappears
priya
Post by priya » Thu Oct 07, 2010 3:36 pm
Some portion of the line in Top area of chart disappears.
I have line series. Some portion of the line series in the Top area of the chart disappears. Have attached sample to reproduce same. The last 3 points are not drawn. Following are the values added to datasoure for the YMember of the series.
curves[0].Index2 = 11.438;
curves[1].Index2 = 26.072;
curves[2].Index2 = 55.339;
curves[3].Index2 = 58.670;
curves[4].Index2 = 62.000;
curves[5].Index2 = 68.000;
curves[6].Index2 = 74.000;
curves[7].Index2 = 76.000;
curves[8].Index2 = 78.000;
curves[9].Index2 = 79.333;
curves[10].Index2 = 80.667;
curves[11].Index2 = 82.000;
curves[12].Index2 = 82.000;
curves[13].Index2 = 82.000;
curves[14].Index2 = 82.000;
Priya
TeechartSample.zip
Sample project
(10.54 KiB) Downloaded 252 times
Re: Some portion of the line in Top area of chart disappears
Post by Sandra » Fri Oct 08, 2010 11:34 am
Hello priya,
I have added SetMinMax() method in your code and seems works fine for me using last version 4. Please add next changes in your code and try again if your problem is solved:
 private void AddSeries()
            Steema.TeeChart.WPF.Styles.Line line = new Steema.TeeChart.WPF.Styles.Line();
            line.DataSource = curves;
            line.XValues.DataMember = "Index";
            line.YValues.DataMember = "Index2";
            tchart.Series.Add(line);
            tchart.Axes.Left.SetMinMax(line.YValues.Minimum, line.YValues.Maximum+3);
            tchart.Axes.Left.Increment = 5;
priya
Post by priya » Mon Oct 11, 2010 11:27 am
Thanks. This helps.
Priya
