Problem by starting Tee Chart application in web browser
Brinet
Post by Brinet » Fri Oct 29, 2010 8:56 am
I have a following problem. We are developing web based application for plant reporting that usese Tee chart
components. The application is XBAP application written in c#, communication with the server is WCF based and presentation layer is
made with WPF. The problem occurs when the client tries to reach the page where Tee chart graph should be used. The application is
published on the remote server and clients should be able to reach it's content quite easily, just by entering simple URL in the
web browser. However what we get is the error message that I am sending you in the attached file. I would be very grateful if you could help me
solve this, for me currently huge problem. It's quite urgent so I hope you can understand me.
Thank you in advance.
New WinZip-Datei.zip
(5.12 KiB) Downloaded 630 times
Re: Problem by starting Tee Chart application in web browser
Post by Sandra » Tue Nov 02, 2010 11:27 am
Hello Brinet,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
Waz
Post by Waz » Thu Nov 04, 2010 10:00 am
Hi Brinet
I am having a similar problem and started a topic a couple days ago about this. The answers I got back was that the license.licx for some reason is not included in the application however no replies yet as to how to get this in.
If you get an answer for this please let me know in this topic:
http://www.teechart.net/support/viewtop ... 88&start=0
Waz
