Conditional Color Axis Label Color
TestAlways
Post by TestAlways » Thu Dec 09, 2010 4:22 pm
I have a user's request to change the color of an axis label based on the value that the label represents.
I tried the following code:
  Series1.FillSampleValues(20);
  Series2.FillSampleValues(20);
  Chart1.BottomAxis.OnDrawLabel := DrawBottomAxis;
procedure TForm1.DrawBottomAxis(Sender:TChartAxis; var X,Y,Z:Integer; var Text:String;
  var DrawLabel:Boolean);
  lValue: Integer;
  lValue := StrToIntDef(Text, -1);
  if lValue < 0 then
    Sender.LabelsFont.Color := clRed
  if ((lValue mod 2) = 1) then
    Sender.LabelsFont.Color := clGreen
    Sender.LabelsFont.Color := clYellow;
but it didn't change the font colors--they are always black.
How can I change individual axis label font colors?
Thank you,
Ed Dressel
ChartIt
Re: Conditional Color Axis Label Color
Post by ChartIt » Fri Dec 10, 2010 3:56 am
Maybe this thread is relevant for you:
http://www.teechart.net/support/viewtop ... =3&t=11883
TestAlways
Post by TestAlways » Fri Dec 10, 2010 7:07 pm
Thanks. That works.
I was looking at the source and saw that a TList was used (rather than a TObjectList) so I assumed calling .Clear would not free the objects. I see that you implemented your own Clear method and freed the objects. Just curious, why wasn't a TObjectList used rather than a TList?
Thank you,
Ed Dressel
TestAlways
Post by TestAlways » Fri Dec 10, 2010 8:23 pm
In testing, when adding labels, the 'smarts' used to be sure labels do not over-right each other is gone, and they axis labels can be impossible to read.
I really don't want the 'over-right smarts' to go away.
Is there a solution for this?
Post by Narcís » Thu Dec 16, 2010 12:34 pm
Hi Ed,
Sorry for the delayed reply. I'm afraid not. Colouring labels should be possible using standard labels. This is a bug(TV52015315) as Yeray posted here.
TestAlways
Post by TestAlways » Tue Dec 21, 2010 8:18 pm
[At least] One more question...
After I add labels to the bottom axis, if I reset the series but don't add customized labels, the axis do not appear at all.
See the attached demo--
1) When it is first started, black labels from 0... 19 show up.
2) Checking "Custom color captions" at the top and one red caption shows in place of the black ones.
3) Un-checking the check box results in no labels being shown for the bottom axis.
How can I get the standard labels to appear in #3?
Ed Dressel
Axis Label Colors.zip
(3.14 KiB) Downloaded 801 times
Post by Yeray » Wed Dec 22, 2010 10:16 am
Hi Ed,
TestAlways wrote:How can I get the standard labels to appear in #3?
Setting the labels to be automatic when the checkbox isn't checked (add an "else" to your condition):
Chart1.Axes.Bottom.Items.Automatic:=true;
Post by Yeray » Wed Jan 05, 2011 3:09 pm
Hi Ed,
I'd like to inform you that the bug with number [TV52015315] has been closed as described here
