Any form with TeeChart object takes 8-10 seconds to load
sfree82
Post by sfree82 » Tue Dec 14, 2010 12:26 pm
Strange issue that has been noted on 2 systems, both running Win XP SP3. Any form with a TeeChart v8.0.0.8 object on it takes about 10 seconds to get from the stage where the load is requested to the Form_Load event. Found a bizarre solution on each that turning off the WiFi adapter meant that the delay was no longer present. Any ideas as to why the WiFi adapter being turned on would cause a delay?
Re: Any form with TeeChart object takes 8-10 seconds to load
Post by Yeray » Wed Dec 15, 2010 1:44 pm
Hi sfree,
Is it an ASP application? I'm wondering if the problem can be something similar to what was discussed here
cinimod
Post by cinimod » Wed Dec 15, 2010 5:56 pm
This is an old winforms app written in VB6 using the teechart OCX control so shouldn't have anything to do with MS checking of signatures, however you never know! Any chance of getting a copy of that unsigned OCX mentioned in the other thread as a test?
Are there any debug logs that can be enabled in the OCX that would help you track down where the pause is occurring?
sfree82
Post by sfree82 » Thu Dec 16, 2010 8:34 am
Oooooops - logged in using the wrong licence number for the previous reply! Previous reply by 'cinimod' was actually from me; must stop masquerading as colleagues on the internet...
Post by Yeray » Thu Dec 23, 2010 9:52 am
Excuse the delayed reply. I've just sent you the TeeChart7.ocx unsigned.
I've sent it to the registered mail the account sfree82 has in this forums.
I hope it helps.
