TChartPreviewer
jpm
TChartPreviewer
Post by jpm » Mon Dec 27, 2010 1:04 pm
I am Using the component 'TChartPreviewer' to print the TCharts.
I would like to Pre-set some field to some defaults ( for example to check ON the option 'smooth') and if possible to hide or at least lock some fields once the caller will have force the settings to the required ones. The goal is to let the minimum interface, in fact the minimum the SW user will really need.
How can I process?
Thank-you for your answers.
Re: TChartPreviewer
Post by Yeray » Wed Dec 29, 2010 12:09 pm
Hi jpm,
I recommend you to create you custom Previewer. You can simply create a new form, add a TTeePreviewPanel to the form and the checkboxes you want the user to have access.
  with Form2.TeePreviewPanel1 do
    Panel:=Chart1;
    Orientation:=ppoLandscape;
    AsBitmap:=true;
  Form2.Show;
