Chart editor problem
UserLS
Post by UserLS » Tue Mar 08, 2011 8:03 pm
I have a .ten file generated by saving a simple chart using the latest version of TChart (just upgraded). I load this chart and try to edit it.
a. First I tried to use your chart editor. When I bring it up and click on the Titles or Legend tabs I get an exception window with error "Value of '0' is not valid for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'. Parameter name: Value". Clicking on Ok button closes my application.
b. I placed a property grid on my screen hoping that this way I'll get to see the 'Value' and may be even fix it... At least by knowing what is wrong I could programatically change it to the valid value. Well, clicking on Title, Subtitle, Footer and Subfooter produced exactly the same error (but now it is not fatal) and I was not able to get to the title editor. So at this point I cannot edit anything for the 4 objects affected by this problem. Now, our users are saving all their graphs in .ten files and then bring them back to edit / print. This means that none of them will be able to change any setting on the title, subtitle, footer or subfooter of any of their graphs. That means I'll not be able to release our application until you fix it.
Re: Chart editor problem
Post by Sandra » Wed Mar 09, 2011 3:42 pm
Hello UserLs,
I couldn't reproduce your problems using last version of TeeChart.Net and attached project. Please, check if you can reproduce in my project the exception.
TestProject1.zip
(18.5 KiB) Downloaded 555 times
