Gradient not working with bar series in Tee2010.02 Delphi XE
Jays
Post by Jays » Fri Mar 18, 2011 1:29 pm
using latest Tee2010.02 Version with Delphi XE Enterprise under Win 7 64 bit does not allow to activate gradient for bar series (hoz. and vert.).
I used this feature for several years now, but it does not work either in designtime nor in runtime.
The same happens with TAreaseries (I read the post above but the workaround does not work for bar series).
As you can see in the attachment the legend is filled with the desired gradient, but the bars are not.
Everything works fine with e.g TPointSeries and TPieSeries.
Thanks for any solution.
regards
Jo
NoGradient.zip
Screenshots in design and runtime
(72.85 KiB) Downloaded 368 times
Re: Gradient not working with bar series in Tee2010.02 Delphi XE
Post by Sandra » Fri Mar 18, 2011 3:09 pm
Hello Jay,
If you want change gradient of Bar Series, you need change BarStyle property to Rectangle Gradient, as do in next lines of code:
uses Series;
  Chart1.View3D:=false;
    FillSampleValues(3);
    BarStyle:=bsRectGradient;
    Gradient.Visible:=true;
  Chart1.Draw;
Could you tell us if previous code works as you expected?
Jays
Post by Jays » Fri Mar 18, 2011 3:41 pm
It works perfectly!
Thank you!
This needs to implemented in the Charteditor for your future works...
Jays
Post by Jays » Fri Mar 18, 2011 3:54 pm
Oh, sorry. It's already implemented.
Everything is fine!
