I can not remove the shadow (marks)
Pense
Post by Pense » Mon Jun 13, 2011 5:49 pm
The shadow of the marks does not work on DBChart (TeeChart Standard v2011 VCL - Delphi 7)
At runtime:
/ / does not work
MyDBChart.Series [0]. Marks.Shadow.Visible: = False;
/ / does not work
MyDBChart.Series [0]. Marks.Shadow.Transparency: = 100;
/ / This works fine
MyDBChart.Series [0]. Marks.FontSeriesColor: = True;
How do I remove the shadow?
Re: I can not remove the shadow (marks)
Post by Yeray » Wed Jun 15, 2011 9:18 am
Hello Pense,
I'm not able to reproduce the problem here. Are you using the latest version available (v2011.03.30407)?
The three lines you mentioned seem to work as expected for me here with a TPointSeries and a TBarSeries.
Pense
Post by Pense » Thu Jun 16, 2011 4:18 am
Oi Yeray,
Obrigado por responder ao meu post. O cenário do meu problema é o seguinte:
No formulário eu tenho um Button e um DBChart apenas, além de 3 procedimentos. O problema todo foi provocado por um pequeno algoritmo no evento OnShow do formulário que oculta todas as Marks cujo valor seja igual a zero (YValue = 0).
(DBChart1.AddSeries(TBarSeries) as TBarSeries).FillSampleValues();
procedure TForm1.FormShow(Sender: TObject);
var i: integer;
// exemplo
DBChart1.Series[0].YValue[1]:= 0;
// após executar este algoritmo, o evento do botão deixa de funcionar
// Exit;
with DBChart1.Series[0] do
for i:= 0 to (Count-1) do
Marks.Visible:= YValue>0;
// Evento atribuído ao botão (TButton) que está no Formulário
procedure TForm1.BtnShadowClick(Sender: TObject);
with DBChart1.Series[0].Marks.Shadow do
Visible:= not Visible;
Post by Narcís » Thu Jun 16, 2011 8:51 am
Hi Pense,
I could reproduce the issue here now and added it (TV52015618) to the defect list to be investigated. As an alternative, there's a much easier way to hide marks which is using the OnGetMarkText event as shown here:
uses Series;
  DBChart1.AddSeries(TBarSeries.Create(Self)).FillSampleValues;
  DBChart1[0].OnGetMarkText := Series1GetMarkText;
//var i: integer;
  DBChart1[0].YValue[1]:= 0;
  //Hidding Marks with Y = 0 in loop below makes marks shadow not responsive
  //Exit;
  {with DBChart1[0] do
      Marks[i].Visible:= YValue[i]>0;
  with DBChart1[0].Marks.Shadow do
procedure TForm1.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: String);
  if MarkText=IntToStr(0) then MarkText:='';
Doing so marks shadow visibility can be toggled.
Hope this helps!
Pense
Post by Pense » Thu Jun 16, 2011 1:46 pm
Oi Narcís,
Sim, está resolvido. Muito obrigado!
Ficou assim:
if Sender.YValue[ValueIndex] = 0 then
MarkText:='';
