I am switching from TeeChart Pro v7.0.0.7[ActiveX] to TeeChart .Net Pro v.4.0.2011.2082.
I have observed an issue with the Chart Controller that if we “Move” .Net graph and then press “3D”, .Net control’s left and bottom axes remain in the previous location and remaining graph come in a normal/original position. I have attached a document in which behavior of .Net and Active X control is explained in this regard. This document have print shots from a sample program.
Hope the problem will be clear with the help of attached document.
Thanks and Regards,
Maverick
Move and then 3D, Axes remain in previous location.
- Newbie
- Move and 3D Ques.zip
- Doc. attached for better understanding of the problem
- (113.02 KiB) Downloaded 325 times
Re: Move and then 3D, Axes remain in previous location.
Hello Maverick123,
I couldn't reproduce your problem using last version of TeeChart.Net. I recommend you that update your version of TeeChart.Net that you can find in Customer Download Page and try again if the problem persist.
- Newbie
Thanks for the reply.
Infact i am finalizing my application now and this point was still pending on my side. Thats why my reply seems to be a little late.
At this stage i cannot change the version of TeeChart. Can you please confirm whether this issue exists in the version i am using i.e. TeeChart .Net Pro v.4.0.2011.2082?
Thanks and Regards,
Maverick
Thanks and Regards,
Maverick
Hello Maverick123,
Yes, the problem occurs in build number v.4.0.2011.2082 of TeeChart.Net.
