TeeCreateBitmap doesn't work if panel color is clWhite
jls
Post by jls » Fri Aug 05, 2011 12:38 pm
If the color of the panel is clWhite, this code doesn't work:
ABitmap := Chart.TeeCreateBitmap;
The series is not visible.
This a workaround:
ABitmap := Chart.TeeCreateBitmap(TColor($FEFEFE), Chart.GetRectangle);
This seems to work since TColor($FEFEFE) <> the color of the panel.
How can this be fixed?
TeeChart v2011.03.30407
Delphi XE
Jørgen
Re: TeeCreateBitmap doesn't work if panel color is clWhite
Post by Yeray » Mon Aug 08, 2011 8:15 am
Hello Jørgen,
I can't see any strange behaviour with the following code in v2011.03, am I missing something?
I see the same behaviour with clWhite and clRed.
uses Chart, ExtCtrls;
var Chart1: TChart;
    Image1: TImage;
  Chart1:=TChart.Create(self);
  Chart1.Parent:=Form1;
  Chart1.Color:=clWhite; //clRed;
  Image1:=TImage.Create(self);
  Image1.Parent:=Form1;
  Image1.BoundsRect:=Chart1.BoundsRect;
  Image1.Top:=Chart1.Height;
var ABitmap: TBitmap;
  ABitmap:=Chart1.TeeCreateBitmap;
  Image1.Picture.Bitmap:=ABitmap;
jls
Post by jls » Mon Aug 08, 2011 12:59 pm
Added a sample that doesn't work
It is something wrong with load from stream
(It works the second time you click)
Jørgen
Project2.zip
(84.96 KiB) Downloaded 576 times
Post by Yeray » Tue Aug 09, 2011 9:06 am
Hello Jørgen,
Try forcing a Chart repaint after changing the color:
  Chart1.Color := clRed; //works
  Chart1.Draw;
jls
Post by jls » Tue Aug 09, 2011 9:42 am
It worked.
What is the reason?
Is it a bug?
Jørgen
Post by Yeray » Tue Aug 09, 2011 2:42 pm
Hi Jørgen,
This is because TeeCreateBitmap function uses the internal Bitmap already created instead of creating a new one when UseBuffer=true (as per default). So another alternative would be setting it to false:
Chart1.Canvas.UseBuffer:=false;
