Exporting WMF
Mikko Alaja
Exporting WMF
Post by Mikko Alaja » Tue Aug 31, 2004 7:49 am
The WMF export doesn't seem to work properly anymore. The files created in this manner have a size of 0KB. We tried to use the code example provided by Steema to create a WMF image to the clipboard and then save it as a file, but the quality of the WMF produced in this way is of a lowly GIF level. Could it be that the WMF vector graphic files are created as raster files? Or have we screwed up somehow?
Has anyone else had this kind of problems? Does anyone know an answer?
Cheers,
Mikko
Post by Christopher » Tue Aug 31, 2004 11:36 am
Hi Mikko,
No, this is a problem that has been reported before; I have now qualified the issue as 'extreme' urgency on our list of defects.
Thank you!
http://groups.google.com
http://codenewsfast.com/
Mikko Alaja
Latest release helped, but still problems
Post by Mikko Alaja » Mon Nov 15, 2004 7:32 am
Excellent...! Installing the latest release helped with the WMF exporting problem and I am now able to create true vector graphic WMF image files.
But we noticed an another thing: If we use the X axis label as a "multiline" label and create a WMF image there's nothing on the second line of the multiline. But, if I create a GIF image, the second line of the label is showing correctly.
For example, if I have the first line of the X axis label showing the months (from 1 to 12) and the second line showing the year information ("2004"), there's no year in a WMF image but there is one in a GIF image.
Cheers,
Mikko
Post by Pep » Mon Nov 15, 2004 9:38 am
Hi Mikko,
I've just tried here using ths following simple code and works fine :
private void Form1_Load(object sender, System.EventArgs e)
tChart1.Axes.Bottom.Labels.MultiLine = true;
bar1.Add(10,"Hello"+"\n"+"World");
private void button2_Click(object sender, System.EventArgs e)
saveFileDialog1.ShowDialog();
tChart1.Export.Image.Metafile.Save(saveFileDialog1.FileName);
Which code are you using ?
