Weeknum functionality
peters
Post by peters » Thu Nov 10, 2011 12:38 pm
Does TeeChart support weeknum date format in chart settings? I have weekly collected data and I want to label my X-axis as
01/2011, 02/2011 etc.
where first number is a week number in the year.
Peters
Re: Weeknum functionality
Post by Yeray » Thu Nov 10, 2011 3:52 pm
Hi Peters,
I'm afraid it's not supported automatically. But you can always format the axis labels at OnDrawLabel event as in the example at "All features\Welcome !\Axes\First and Last Labels".
Post by Narcís » Thu Nov 10, 2011 3:59 pm
Hi Peters,
For completeness, you may use DateUtils.WeekOfTheYear method for that.
peters
Post by peters » Thu Nov 10, 2011 9:00 pm
Thanks for suggestions.
Maybe in the next releases you will consider something like ''ww/yyyy" in date formating options. It would be useful improvement :-).
Peters
Post by Yeray » Fri Nov 11, 2011 1:32 pm
Hi Peters,
I've added it to the wish list to be implemented in future releases (TV52015832).
peters
Post by peters » Sat Nov 12, 2011 10:00 am
I have almost found a solution which looks like this:
procedure TMyChart.ChartGetAxisLabel(Sender: TChartAxis;
  Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
const
  WW = 'ww';
  WeekNum : string;
  if Sender.IsDateTime and (pos(WW, Sender.DateTimeFormat) > 0) then
     try
       WeekNum := IntToStr(WeekOfTheYear(StrToDate(LabelText)));
     except
       WeekNum := 'ERR';
     LabelText := StringReplace(LabelText, WW, WeekNum, [rfReplaceAll]);
The problem is that instead of LableText I need original X-axis value, because LabelText is ALREADY formated and StrToDate returns error during convertion. So my question is how to get here oryginal bottom axis value BEFORE formating.
Peters
peters
Post by peters » Sun Nov 13, 2011 8:16 pm
I have dug a little in the source code and I think I have a solution, but it would require changes in source code of TeEngine. Date formatting is done in LabelValue function. It gets its parameter (date value for x-label tick) from DoDeaultLabels procedure, but actual x-value is stored only in temporary tmpValue variable which is not published. So now I can see 3 solutions:
1) publish tmpValue as a property and than us it in OnGetAxisLabel
2) overwrite LabelValue function with code from my previous post
3) overwrite DateTimeToString standard VCL function and implement there the interpretation of "ww" formatting
Because of compatibility with next releases all of them are not safe. Maybe anyone has better idea? :-).
Peters
Post by Yeray » Tue Nov 15, 2011 4:39 pm
Hello Peters,
peters wrote:1) publish tmpValue as a property and than us it in OnGetAxisLabel
The second option is the one I think could be interesting. It will be considered when TV52015832 will be deeply studied.
In the meanwhile, what about using Custom Labels?
uses Series, DateUtils;
var i, last: Integer;
    tmpDate: TDateTime;
    diff: Double;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.Axes.Bottom.LabelsAngle:=90;
  Chart1.Axes.Bottom.DateTimeFormat:='ww/yyyy';
  with Chart1.AddSeries(TFastLineSeries) as TFastLineSeries do
    XValues.DateTime:=true;
    tmpDate:=StrToDateTime('01/01/2011');
    AddXY(tmpDate, random*100);
    for i:=0 to 20 do
      tmpDate:=IncDay(tmpDate,7);
      AddXY(tmpDate, YValue[Count-1] + random*10-5);
    Chart1.Axes.Bottom.Increment:=DateTimeStep[dtOneWeek];
    Chart1.Axes.Bottom.Items.Clear;
    Chart1.Axes.Bottom.Items.Add(XValue[0],StringReplace(FormatDateTime(Chart1.Axes.Bottom.DateTimeFormat,XValue[0]), 'ww', IntToStr(WeekOfTheYear(XValue[0])), [rfReplaceAll]));
    last:=0;
    for i:=1 to Count-1 do
      if (XValue[i]-XValue[last] >= Chart1.Axes.Bottom.Increment) then
        Chart1.Axes.Bottom.Items.Add(XValue[i],StringReplace(FormatDateTime(Chart1.Axes.Bottom.DateTimeFormat,XValue[i]), 'ww', IntToStr(WeekOfTheYear(XValue[i])), [rfReplaceAll]));
        last:=i;
