S-ON-S
- Newbie
Post
by S-ON-S » Thu Jan 19, 2012 2:44 pm
Hi there,
I use the TSurfaceSeries in OpenGl mode. I need the distance to the left axis and the distance to zero point from underneath (in px). I would like move and rotate the Chart.
The values of ChartRect not change if i rotate or move.
I need the distance to calculate the corsor position in my Chart.
See the Image:
Thanks in advance,
Dennis
Post
by Yeray » Fri Jan 20, 2012 4:46 pm
Hi Dennis,
You could try doing something similar to the Calculate2DPosition call in the example
here
S-ON-S
- Newbie
Post
by S-ON-S » Mon Jan 23, 2012 7:37 am
Thanks for the answer, but the problem is not resolved. The x-Position is isn't exact to 100%,
if i use normal mode with opengl and not orthogonal mode. And the y-Postion is wrong. I need the cursor position from the point of origin. I've uploaded an example program.
Thanks in advance,
Dennis
- Example3D.zip
- (85.29 KiB) Downloaded 356 times
Post
by Yeray » Mon Jan 23, 2012 4:13 pm
Hi Dennis,
Right, the CalcXPos, CalcYPos functions seem not to work perfectly in OpenGL. I've just realized it was already identified (
TV52015408).
S-ON-S
- Newbie
Post
by S-ON-S » Tue Jan 24, 2012 7:21 am
is there another possibility to calculate a cross cursor on the x,y,z Value, if I move over with the mouse?
Thanks in advance,
Dennis
Post
by Yeray » Tue Jan 24, 2012 11:04 am
Hi Dennis,
I'm afraid I can't think on another way to do it right now. There is the TSurfaceNearestTool but it uses the Clicked function that at the same time uses the CalcXPosValue/CalcYPosValue function...
