Horizontal Zoom problem
dbrillon
Post by dbrillon » Tue Feb 28, 2012 8:39 pm
When doing a Horizontal zoom the zoom rectangle is not working correctly. In previous version the top and bottom of the zoom rectangle was align with the top and the bottom of the chart. In this version the top of the zoom rectangle is align with the top of the chart but the bottom of the rectangle is align with the Y position of the mouse.
David Brillon
Re: Horizontal Zoom problem
Post by Yeray » Fri Mar 02, 2012 10:34 am
Hi David,
You are right. I've added it to the defect list to be fixed asap (TV52016064).
Thanks for reporting it.
idibaix
Post by idibaix » Mon Apr 16, 2012 9:09 am
SOLUTION:
Modify Chart.pas, procedureTCustomchart.MouseMove, line 3872
Replace:
X1:=xInt;
Y1:=yInt;
With:
X1:= {$IFDEF FMX}Round{$ENDIF}(x); // xInt;
Y1:= {$IFDEF FMX}Round{$ENDIF}(y); // yInt;
Recompile with TeeRecompile.
Post by Yeray » Wed Apr 18, 2012 3:23 pm
Thanks for the fix suggestion. We've applied it slightly modified. The next maintenance release will include it.
dbrillon
Post by dbrillon » Fri Jun 08, 2012 12:12 pm
The source code has not been update in version 2012.05.120327. The problem is still present
Post by Yeray » Fri Jun 08, 2012 2:52 pm
The latest maintenance release (2012.05.120327) was published on 27/03/2012 and the ticket with number TV52016064 was closed after it, on 18/04/2012. The next maintenance release should include it.
dbrillon
Post by dbrillon » Fri Jun 08, 2012 3:04 pm
That explain it! :wink:
