Cannot load package 'Tee916'
gpraet
Post by gpraet » Wed Mar 28, 2012 8:46 am
I just installed TeeChart2012RADXE2.exe (which I downloaded from your site). In Delphi XE2 (update 4) I get: 'Cannot load package 'Tee916'. It contains unit 'VCLTee.TeeGDIPlus', which is also contained in package 'Tee9160' ...
The standard TeeChart, which comes with DXE2, should have been uninstalled, because I can't see these packages in Component/Install Packages ...
Please help!
Giovanni
Re: Cannot load package 'Tee916'
Post by Yeray » Wed Mar 28, 2012 2:11 pm
Hi Giovanni,
gpraet wrote:The standard TeeChart, which comes with DXE2, should have been uninstalled, because I can't see these packages in Component/Install Packages ...
The error message talks about "Tee9160". If the Standard component isn't being loaded, it may be some other component (probably a 3rd party component) using it. So I'd check the packages list and unselect any package you may suspect that could be using TeeChart Standard.
If this solves the problem, you may probably need to recompile the conflictive component to let it use the new TeeChart version.
