Axis title's bounding shape covers legend's checkbox
Khin
Post by Khin » Thu Apr 05, 2012 7:24 am
In my chart, I have right axis title and legend checkboxes next to it. When I rotate the axis title to 270 degree, the checkboxes closer to title are not responding to the click. When I set the the transparency to FALSE, I can see that title text and its bounding shape are separated significantly and the bounding shape covers some of the legend's checkboxes.
If I rotate title to 90 degree, title text and its bounding shape are overlapping each other and do not cover the legend's checkboxes. How could I make title text and its bounding shape overlap in 270 degree or other rotation angle? Or any other way not to cover the legend's checkbox?
Thanks!
Khin
Re: Axis title's bounding shape covers legend's checkbox
Post by Yeray » Thu Apr 05, 2012 3:07 pm
Hi Khin,
I'm not able to reproduce it here. Could you please arrange a simple example project we can run as-is to reproduce the problem here?
Khin
Post by Khin » Thu Apr 12, 2012 12:26 pm
The problem is solved by changing the legend's position Margin. I had the positive value in the Margin field which makes legend and right axis's bounding shape overlap each other when I have long legend list.
Thanks for quick response!
Post by Yeray » Thu Apr 12, 2012 2:52 pm
Hi Khin,
I'm glad to hear you found how to solve it! :D
