Linker error: Unable to open CHART.OBJ
Totte Karlsson
Post by Totte Karlsson » Wed Apr 18, 2012 6:03 am
I have lately been trying to link a package containing some forms using TeeChart, using unilink opposed to ilink32.
I am getting the following linker error:
[ILINK32 Error] Fatal: Unable to open file 'CHART.OBJ'
I have the following in my pavckage cpp file:
#pragma comment(lib, "Tee915.bpi")
#pragma comment(lib, "TeePro915..bpi")
#pragma comment(lib, "TeeUI915.bpi")
Any help appreciated.
I am using Rad Studio C++ XE and TeeChart pro Version 2011.03.30407
totte
Re: Linker error: Unable to open CHART.OBJ
Post by Yeray » Wed Apr 18, 2012 3:17 pm
Hi Totte,
Please, make sure the TeeChart Include path is in the IDE Include list and the TeeChart Lib and Lib\Obj paths are in the IDE Library list.
Then, try if a new simple project with just a chart on the form works fine. If so, the problem should be a wrong reference in the old project. If that's the case, you should correct it manually editing (with notepad or similar) the project files and correcting any wrong reference you may find.
Totte Karlsson
Post by Totte Karlsson » Wed Apr 18, 2012 4:51 pm
I correct my first post, I'm not using unilink, but the regular ilink32
I created a new package, added a form with a TeeChart on and checked all paths.
I have
C:\Program Files (x86)\Steema Software\TeeChart 2011 for Delphi 2011\Delphi15\Lib
C:\Program Files (x86)\Steema Software\TeeChart 2011 for Delphi 2011\Delphi15\Lib\Obj
in the Library path and
C:\Program Files (x86)\Steema Software\TeeChart 2011 for Delphi 2011\Delphi15\Include
in the include path
I even re-installed Tee from scratch and still get that linker error
This is puzzling..?
tk
Post by Yeray » Fri Apr 20, 2012 1:01 pm
Hi Totte,
Please, take a look at the article here:
http://zachsaw.blogspot.com.es/2008/10/ ... -file.html
