Right Axis with Label
Matt Venkat
Post by Matt Venkat » Tue Apr 24, 2012 7:36 am
I want to add Right Axis with Label. The image below has Left, Right and Bottom Axis with label.
I set the following setting from the "Editing TeeChart" from.
[Chart|Axis|Right Axis]
Visble (Checked)
Round First(Checked)
Label on Axis (Checked)
Angel(90)
But There is no label on the Right axis.
Please help me out.
Thanks in advance
Re: Right Axis with Label
Post by Yeray » Wed Apr 25, 2012 9:20 am
Hi Matt,
The right axis in your picture already seems to show some labels. What you probably want to change is the axis label style. You can change it through the editor at Chart\Axis tab, select Right axis, Labels\Style tab. There you can change the Style in the combobox with the same name.
