Wrong *.tee file format in LoadChartFromStream
Toreba
Post by Toreba » Thu May 17, 2012 1:26 pm
Using TeeChart Pro 2011.03.30407 for Delphi 2007, I am saving and a chart to stream and then later reloading from that same stream. The LoadChartFromStream call fails with the message 'Wrong *.tee file format'.
If I write the saved chart stream's DataString to file, then a call to LoadChartFromFile works fine.
Any suggestions?
Thanks very much.
Toreba
Re: Wrong *.tee file format in LoadChartFromStream
Post by Yeray » Fri May 18, 2012 9:08 am
Hi Toreba,
Check the stream Position is 0 before loading it.
the following example seems to work fine for me here:
uses Series, TeeStore;
var stream: TMemoryStream;
  with Chart1.AddSeries(TBarSeries) do
    FillSampleValues;
    ColorEachPoint:=true;
procedure TForm1.SaveToStreamClick(Sender: TObject);
  stream:=TMemoryStream.Create;
  SaveChartToStream(Chart1, stream);
procedure TForm1.ClearChartClick(Sender: TObject);
  Chart1.ClearChart;
procedure TForm1.LoadFromStreamClick(Sender: TObject);
var tmpChart: TCustomChart;
  if stream<>nil then
    stream.Position:=0;
    Chart1.Free;
    tmpChart:=TChart.Create(Self);
    LoadChartFromStream(tmpChart, stream);
    Chart1:=tmpChart as TChart;
    Chart1.Parent:=Self;
Toreba
Post by Toreba » Tue May 29, 2012 2:19 pm
Yes, that works! Thanks very much Yeray.
