Tooltip in a point serie
JAV
Post by JAV » Wed Aug 22, 2012 5:25 pm
We are working in a chart with point series (TeeChart8.ocx). We are using the following instruction to add values or points to the serie:
Series(i):addxy(dfecha,dvalor,observaciones,0).
In the x-axis we have date and a value in y-axis, we need to add a tooltip to each point with an extent information which is in "observaciones". We are setting the serie as follows:
Series(i):XValues:DateTime=True
But instead of have the dates on X-axis we have the information of the "observaciones" field. Is it correct to use the third parameter of Series(i) instruction to add a tooltip? Is there any other way to display the information on a tooltip keeping at the same time the X-axis values?
Thank you very much, regards,
JAV
Re: Tooltip in a point serie
Post by Yeray » Thu Aug 23, 2012 7:41 am
Hi JAV,
By default, the Axis.Bottom.Labels.Style is set to "talAuto". The "talAuto" Style shows the values when there aren't labels associated to the series points, but the series labels when present.
If you have labels in your series points (and you need to have them to use the tooltip), you can force the bottom axis labels to show the series values setting the Labels Style to "talValue".
In VB6:
TChart1.Axis.Bottom.Labels.Style = talValue
JAV
Post by JAV » Thu Aug 23, 2012 2:09 pm
Hi Yeray:
Thanks a lot. Works just as I need it.
Best regards,
JAV
