TPointSeries and colors of pointer
Friis
Post by Friis » Mon Sep 10, 2012 7:40 am
When I use the code
AddXY(xvalues,yvalues);
I can change the color of the point afterwards. BUT if i use the code
AddXY(xvalue,yvalue,'',cllime);
I CANNOT change the color - see the code below. The code in Button1 is OK - the code in Button2 is Not ok....
I'm using CodeGear™ Delphi® 2007 for Win32® R2 Version 11.0.2902.10471 with Steema Teechart Pro v2012.05.120327 32BIT VCL
procedure TForm10.Button1Click(Sender: TObject);
i : integer;
Chart1.RemoveAllSeries;
Chart1.FreeAllSeries();
Chart1.Title.Text.Clear;
Chart1.Legend.Shadow.Visible := false;
Chart1.View3D := false;
Chart1.BottomAxis.DateTimeFormat := 'yyyy-mm-dd ' + #13 + 'hh:nn:ss';
Chart1.BottomAxis.Automatic := true;
Chart1.AddSeries(TPointSeries.Create(self));
Chart1[0].ParentChart := Chart1;
Chart1[0].XValues.DateTime := true;
for I := 0 to 9 do
  Chart1[0].AddXY(now+i/10,i);
if Chart1.SeriesCount >0 then
  with Chart1[0] as TpointSeries do
      Pointer.Color := clred;
      Pointer.Brush.Color :=  clred;
      Pointer.Brush.Style := bsSolid;
      seriescolor :=  clred;
procedure TForm10.Button2Click(Sender: TObject);
i : integer;
for I := 0 to 9 do
  Chart1[0].AddXY(now+i/10,i,'',cllime);
      Pointer.Color := claqua;
      Pointer.Brush.Color :=  claqua;
      seriescolor :=  claqua;
Re: TPointSeries and colors of pointer
Post by Yeray » Mon Sep 10, 2012 8:40 am
Hi Friis,
Right. The color set to the points prevails to the color set to the series. This is a per-design behaviour.
If you want to reset the color set to the points so the color set to the series can be used, you can set all the points color to clTeeColor prior:
procedure TForm1.Button2Click(Sender: TObject);
var i : integer;
  for I := 0 to 9 do
      for I := 0 to Count-1 do
        ValueColor[I]:=clTeeColor;
