Basic how to do...
FTOptions
Basic how to do...
Post by FTOptions » Thu Nov 15, 2012 6:41 pm
I am trying to change the font size for the bottom labels using
tChart1.Axes.Bottom.Labels.Font.Size = 4;
I can change the left labels, but not the bottom.
In xaml, how can the chart be sized and positioned within the container?
How can the axis titles be moved?
Re: Basic how to do...
Post by Sandra » Fri Nov 16, 2012 12:21 pm
Hello FTOptions,
I am trying to change the font size for the bottom labels using tChart1.Axes.Bottom.Labels.Font.Size = 4;I can change the left labels, but not the bottom.
I use your code in last versions of TeeChartFor.Net and your problem doesn't appear for me, so, the size of labels of all axes, change form me using next code:
  tChart1.Axes.Bottom.Labels.Font.Size = 14;
            tChart1.Axes.Left.Labels.Font.Size = 14;
The size and the position depends of the size of Window or container are you using in xaml,therefore, the size and position you want give to your chart, only must consider the size of Chart mustn't be more big as size of container or Window.
To move the axis titles you need move the axis, too, because, the title depends of axis. I suggest you some options to achieve change position of title:
Firts: Change the text align of Title of Axes as do in next lines of code:
            Steema.TeeChart.WPF.Styles.Line line = new Steema.TeeChart.WPF.Styles.Line(tChart1.Chart);
            line.FillSampleValues();
            //Vertical axis
            line.VertAxis = Steema.TeeChart.WPF.Styles.VerticalAxis.Both;
            tChart1.Axes.Left.Title.Visible = true;
            tChart1.Axes.Left.Title.Text = "Left Axis";
            tChart1.Axes.Left.Title.TextAlign = TextAlignment.Right;
            tChart1.Axes.Left.Title.Font.Size = 12;
            tChart1.Axes.Left.Title.Font.Bold = true;
            tChart1.Axes.Right.Title.Visible = true;
            tChart1.Axes.Right.Title.Text = "Right Axis";
            tChart1.Axes.Right.Title.TextAlign = TextAlignment.Center;
            tChart1.Axes.Right.Title.Font.Color = Colors.Red;
            tChart1.Axes.Right.Title.Font.Size = 12;
            tChart1.Axes.Right.Title.Font.Bold = true;
            //Horizontal axis
            line.HorizAxis = Steema.TeeChart.WPF.Styles.HorizontalAxis.Both;
            tChart1.Axes.Top.Title.Visible = true;
            tChart1.Axes.Top.Title.Text = "Top Axis";
            tChart1.Axes.Top.Title.TextAlign = TextAlignment.Left;
            tChart1.Axes.Top.Title.Font.Color = Colors.Red;
            tChart1.Axes.Top.Title.Font.Size = 12;
            tChart1.Axes.Top.Title.Font.Bold = true;
            tChart1.Axes.Bottom.Title.Visible = true;
            tChart1.Axes.Bottom.Title.Text = "Bottom Axis";
            tChart1.Axes.Bottom.Title.TextAlign = TextAlignment.Right;
            tChart1.Axes.Bottom.Title.Font.Size = 12;
            tChart1.Axes.Bottom.Title.Font.Bold = true;
Second: Draw directly in the wpf canvas and choose the position as you want the text is drawn. You can do something as next:
            tChart1.Legend.Visible =false;
            tChart1.AfterDraw +=new Steema.TeeChart.WPF.PaintChartEventHandler(tChart1_AfterDraw);
            BitmapSource bmp = tChart1.Chart.Bitmap(tChart1.Width, tChart1.Height);
        private void tChart1_AfterDraw(object sender, Steema.TeeChart.WPF.Drawing.Graphics3D g)
            tChart1.Panel.MarginBottom = (int)(tChart1.Axes.Bottom.MaxLabelsWidth() + tChart1.Panel.MarginBottom);
            double index = tChart1.Axes.Bottom.MaxLabelsWidth();
            g.Font.Color = Colors.Red;
            g.Font.Bold = true;
            g.TextAlign = TextAlignment.Left;
            g.TextOut(tChart1.Axes.Bottom.IAxisSize/2,tChart1.Axes.Left.IEndPos+tChart1.Panel.MarginBottom,"Bottom Text");
FTOptions
Post by FTOptions » Fri Nov 16, 2012 2:17 pm
I do not understand why my bottom axis font is not changing, the left is not a problem. Are there any dependencies that would prevent the font from changing? Something else I noticed, is that when I set the font size larger, the axis moves up to allow for the larger font, but the labels are always at size 8. Also, when I use a multi-line label for the bottom axis, the title position is not adjusted and labels are over-written by the title.
Is there some documentation describing best practices for layout? There is a lot of dead space by default and I would like to make the chart as large as possible within the container.
I will use your examples to adjust the chart size.
Thanks for your reply
FTOptions
Post by FTOptions » Fri Nov 16, 2012 2:38 pm
I figured out my bottom axis issue. When I override the labels, the font size sticks at 8. When I remove the override, the font size changes. Here is how I was setting the labels in my test app:
for ( int i = 0; i <= 40; i += 5 )
tChart1.Axes.Bottom.Labels.Items.Add( i, string.Format( "{0}", ( i * 1.36 ).ToString( "0.00" ) ) );
It is a simple line series that I set the bottom axis to minmax of (0,40).
Ultimately, I want to set the bottom labels to 2 lines of text.
Post by Sandra » Fri Nov 16, 2012 4:24 pm
Hello FTOptions,
I have made as simple code, where I have changed the Size of Labels, I have added a custom Title using TextOut and I have actived the MultiLine property of Labels and works in my correct way using last version of TeeChartNet:
  public MainWindow()
        const int Fontsize1 = 15;
            line.FillSampleValues(40);
            tChart1.Axes.Bottom.Labels.Items.Clear();
            for (int i = 0; i < 40; i += 5)
                tChart1.Axes.Bottom.Labels.Items.Add(i,  (i * 1.36).ToString("0.00"));
             //Change Size of Labels.
            foreach (Steema.TeeChart.WPF.AxisLabelItem LabelItems1 in tChart1.Axes.Bottom.Labels.Items)
                LabelItems1.Font.Size = Fontsize1;
            tChart1.Panel.MarginUnits = Steema.TeeChart.WPF.PanelMarginUnits.Pixels;
            tChart1.Axes.Bottom.Labels.MultiLine = true;
            tChart1.AfterDraw += new Steema.TeeChart.WPF.PaintChartEventHandler(tChart1_AfterDraw);
            BitmapSource bmp1 = tChart1.Chart.Bitmap(tChart1.Width, tChart1.Height);
            g.ClearClipRegions();
            tChart1.Panel.MarginBottom = (int)(tChart1.Axes.Bottom.MaxLabelsWidth() + tChart1.Panel.MarginBottom + Fontsize1);
            g.Font.Size = Fontsize1;
            g.TextOut(tChart1.Axes.Bottom.IAxisSize / 2, tChart1.Axes.Left.IEndPos + tChart1.Axes.Bottom.MaxLabelsWidth(), "Bottom Text");
Can you tell us if previous code works in your end.
As I have explained previously, the maximum size of chart depends of size of MainWindow, for example, if your MainWindow has height = 400 and width=300, you only can make the chart as maximum of the height and width of MainWindow of wpf project, therefore you need increase the MainWindow size, if you want chart taking more space.
If you want change the size of Chart you only need do next:
tChart1.Height=X;
tChart1.Width =Y;
FTOptions
Post by FTOptions » Fri Nov 16, 2012 5:37 pm
Using your example, this is what I get. Initially, I do not see the bottom title and the labels are slightly hidden.
When I size the window, I get a crash.
A couple of things:
1 - I notice you explicitly set the font size for each label, why? Shouldn't it get set based on the Labels.Font.Size?
2 - Why doesn't the sizing/positioning/rendering engine determine when a lable has multilines and adjust accordingly.
I should not have to manually move the title. This sounds like a bug.
3 - My question about sizing has nothing to do with the size of the window. It is the size of the chart within the window.
I want to make the chart as large as possible within the given size. I have not been able to change the panel
size. Should chart attribute changes always be made in the beforedraw handler? This may be part of my frustration.
What is the proper practice?
Post by Sandra » Mon Nov 19, 2012 11:46 am
Hello FTOptions,
You need change for each label size,so each custom label is independent object in the axes, therefore each custom label has its properties and it doesn't depend of properties of Labels of axes for example Axis.Labels.Font.Size based.
2 - Why doesn't the sizing/positioning/rendering engine determine when a lables has multilines and adjust accordingly.
Ok. I have added your request in wish-list with number [TF02016420] to be consider it in future versions of TeeChartFor.Net.
When you create a wpf project in the work area you have a MainWindow and Grid, if you want do the tChart as large possible you need assign the height or width of window to tchart height or width. An option to achieve it is, revoming the grid of xaml code:
<Window x:Class="WpfApplication2.MainWindow"
        xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation"
        xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml"
        Title="MainWindow" Height="484" Width="840" xmlns:my="clr-namespace:Steema.TeeChart.WPF;assembly=TeeChart.WPF" SizeToContent="WidthAndHeight">
 <Grid Height=" 484" Width="840">
    <my:TChart Height="371" Name="tChart1" Width="609" />
</Grid>
</Window>
And add tCharct directly in the MainWindow as do here:
</Window>
After doing it you can draw the chart as size you want without problems using beforeDraw and if you want ChangeSize, events as do in next example code:
            tChart1.Panel.MarginBottom = 8;
            tChart1.BeforeDraw += new Steema.TeeChart.WPF.PaintChartEventHandler(tChart1_BeforeDraw);
            this.SizeChanged += new SizeChangedEventHandler(MainWindow_SizeChanged);
        void tChart1_BeforeDraw(object sender, Steema.TeeChart.WPF.Drawing.Graphics3D g)
            tChart1.Width = this.Width;
            tChart1.Height = this.Height;
        void MainWindow_SizeChanged(object sender, SizeChangedEventArgs e)
Can you please, tell us if previous code works as you want? If you have any problems please, let me know.
Post by Sandra » Tue Apr 09, 2013 11:12 am
Hello FTOptions,
After doing some test, we have considered the feature request number (TF02016420) isn't implemented. The reason, is that the automatically adjust of labels in the chart is only produced, when the labels are added in chart automatically, as you can see in next example of code:
        Random rnd = new Random();
            line.Add(rnd.NextDouble(), (i * 1.36).ToString("0.00"));
        tChart1.Axes.Bottom.Labels.Font.Size = Fontsize1;
        tChart1.Axes.Bottom.Title.Text = "Bottom Text";
        tChart1.Axes.Bottom.Title.Font.Size = Fontsize1;
In the case labels are added manually, when you use e.g, tChart1.Axes.Bottom.Labels.items.Add(), these aren't drawn automatically and adjust of labels in the chart must be manual, as do in next simple code:
        tChart1.Axes.Bottom.Title.AutoPosition = false;
        tChart1.Axes.Bottom.Title.Top = tChart1.Height - Fontsize1 * 2;
        tChart1.Axes.Bottom.Title.Left = tChart1.Width / 2 - Utils.Round(tChart1.Graphics3D.TextWidth(tChart1.Axes.Bottom.Title.Text) / 2);
        tChart1.Panel.MarginBottom = Fontsize1 * 3;
Our conclusion is TeeChart works in correct way and the behavior,appears when the labels aren't drawn automatically, doesn't need be changed.
