minor ticks at arbitrary positions logarithmic scale?
Errol
Post by Errol » Sun Dec 16, 2012 12:51 am
First of, excuse my ignorance of logarithmic scales, but I have a very specific request regarding minor ticks. My client want a graph with a different number of minor ticks according to different decades. For example, if the decade is less than 1 he wants 10 labels(1, 2, 3, 4, 5, 6, 7, 8, 9, 10) and the following minor ticks (1.5, 2.5, 3.5, 4.5, 5.5, 6.5, 7.5, 8.5 ,9.5)
If the decade is 1 to 2, he wants the following labels(1, 2, 3, 4, 5, 6, 8, 10) and the following minor ticks (1.5, 2.5, 3.5, 4.5, 5.5, 7, 9)
If the decade is 2 to 3, he wants the following labels(1, 2, 3, 4, 7, 10) and the following minor ticks (1.5, 2.5, 5, 6, 8, 9)
Any help much appreciated. I can't find how to override the tick marks so I can place them at custom points. I have figured out custom labels though.
Re: minor ticks at arbitrary positions logarithmic scale?
Post by Yeray » Mon Dec 17, 2012 12:12 pm
Hi Errol,
Errol wrote:if the decade is less than 1 he wants 10 labels(1, 2, 3, 4, 5, 6, 7, 8, 9, 10) and the following minor ticks (1.5, 2.5, 3.5, 4.5, 5.5, 6.5, 7.5, 8.5 ,9.5)
I'm not sure about what do you mean with the "decade", but here you have an example of how you could have labels at 1, 2, 3,... and a minor tick between each 2 labels:
uses Series;
var i: Integer;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.AddSeries(TFastLineSeries).FillSampleValues(10);
  for i:=0 to Chart1[0].Count-1 do
    Chart1[0].XValue[i]:=i+1;
  Chart1.Axes.Bottom.SetMinMax(1, 10);
  Chart1.Axes.Bottom.MinorTickCount:=1;
Errol wrote:If the decade is 1 to 2, he wants the following labels(1, 2, 3, 4, 5, 6, 8, 10) and the following minor ticks (1.5, 2.5, 3.5, 4.5, 5.5, 7, 9)
Here we have non-equidistant labels, so we should use custom labels. The minor ticks are drawn where you want for me here:
uses Series;
var i: Integer;
  Chart1.Axes.Bottom.Items.Clear;
  for i:=1 to 6 do
    Chart1.Axes.Bottom.Items.Add(i, IntToStr(i));
  Chart1.Axes.Bottom.Items.Add(8, '8');
  Chart1.Axes.Bottom.Items.Add(10, '10');
Errol wrote:If the decade is 2 to 3, he wants the following labels(1, 2, 3, 4, 7, 10) and the following minor ticks (1.5, 2.5, 5, 6, 8, 9)
Here the minor ticks are also irregular, so in the example below I used custom labels (like above) and I'm implemented a DrawMinorTick method to draw the custom minor ticks manually:
uses Series, TeCanvas;
var i: Integer;
  for i:=1 to 4 do
  Chart1.Axes.Bottom.Items.Add(7, '7');
  Chart1.Axes.Bottom.MinorTickCount:=0;
  DrawMinorTick(Chart1.Axes.Bottom, 1.5);
  DrawMinorTick(Chart1.Axes.Bottom, 2.5);
  DrawMinorTick(Chart1.Axes.Bottom, 5);
  DrawMinorTick(Chart1.Axes.Bottom, 6);
  DrawMinorTick(Chart1.Axes.Bottom, 8);
  DrawMinorTick(Chart1.Axes.Bottom, 9);
procedure TForm1.DrawMinorTick(axis: TChartAxis; value: double);
var XPos, YPos: Integer;
  Chart1.Canvas.Pen.Color:=axis.MinorTicks.Color;
  Chart1.Canvas.Pen.Width:=axis.MinorTicks.Width;
  Chart1.Canvas.Pen.Style:=axis.MinorTicks.Style;
  if axis.Horizontal then
    XPos:=axis.CalcPosValue(value);
    YPos:=axis.PosAxis+1;
    Chart1.Canvas.Line(XPos, YPos, XPos, YPos+axis.MinorTickLength);
  end
    XPos:=axis.PosAxis;
    YPos:=axis.CalcPosValue(value);
    Chart1.Canvas.Line(XPos, YPos, XPos-axis.MinorTickLength, YPos);
Errol
Post by Errol » Mon Dec 17, 2012 9:54 pm
Thanks for the code, will check it out and report back (no pun intended)
