TeeChart Pro Select X, Y in TeeChart Editor
Bernie07
Post by Bernie07 » Fri Mar 08, 2013 3:28 pm
I have a serious problem. If I'm using the TeeChart Editor adding a new Series (for example Line Chart) and then I'm selecting a MS SQL Datasource in the Page Datasource of the serie.
In the property Label I can select a field but in the properties X and Y I have no chance to select a field. The dataosurce has some integer fields. So I think in the drop down list of X and y there should be this fields.
Have you any ideas why I can't select X and Y for the datasource series. Am I missing something?
Best wishes
Bernhard
Re: TeeChart Pro Select X, Y in TeeChart Editor
Post by Yeray » Mon Mar 11, 2013 11:13 am
Hi Bernhard,
Try to follow the "Tutorial 8 - Database access". I've verified I can set a field for the "X" too.
