Update HTML5 Chart with Realtime Stock Quotes
jzarech
Post by jzarech » Fri Mar 15, 2013 7:59 pm
Is there an easy way to pull data from a database and update an HTML chart with real-time stock prices tic by tic without reloading the whole page. I'm using ASP.Net and SQL server.
I did this before by using frames with server side code that generated javascript and a timer would load new points but that was super kludgy and I'm curious what the best practice is nowadays. That was about 10 years ago I did that page.
Was going to use Silverlight but it's days seem numbered.
Perhaps a javascript db query technique???
Thanks so much!
Joseph
Re: Update HTML5 Chart with Realtime Stock Quotes
Post by Yeray » Wed Mar 20, 2013 2:55 pm
Hi Joseph,
I think calling Chart1.daw() should be enough to refresh the chart. Have you tried it?
See the realtime example in the features demo here.
jzarech
Post by jzarech » Sat Mar 23, 2013 7:13 am
Yes I did see that example and that shows how to refresh the chart and redraw real-time.
I suppose my question is how does one query a datasource real-time using html 5/javascript.
The example seems to generate it's own data and doesn't query a datasource as a stock chart would.
ja
