After add scrollpager the chart dock property doesn't run
I have a example
http://193.145.251.126/pnp/files/KwANvF ... echart.zip
If you run the project and maximize the window, the chart is also maximized. But if you push the button2 (for seeing the scroll pager) and then you maximize the window, the chart is not maximized.
Is that behaviour correct?
Re: After add scrollpager the chart dock property doesn't run
Hello wakeup,
Thanks for your information. I have added the problem in bug list report with number [ID72 ]. We will try to fix it to upcoming versions of TeeChartFor.Net. To following the progress of your bug, I recommend you taking a look in the bug tracker .
I have installed the new version of teechart but I see it is not solved yet. What happened?
Hi wakeup,
As Christopher Ireland commented here, you need to use TChart's Resize event as shown in the bugzilla ticket.
Ok, now it is resized when the is a scrollpager, but if I remove the ScrollPager the chart doesn't resize...
You can either unsubscribe the event when the tool is removed:
or check that the tool exists in the event implementation:
tChart1.Tools.Remove(scrollPager1);
tChart1.Resize -= tChart1_Resize;
void tChart1_Resize(object sender, EventArgs e)
if (tool != null)
tool.Series = num;
I tried it but it still does doesn't resice. In fact the chart doesn't go to his place, there is still below the chart the space ocuped previously by the pagescroller...
- pagescrollerdeleted.png (19.76 KiB) Viewed 18345 times
Hello wakeup,
Using the code below works fine for me. Click the chart to remove the ScrollPager tool. Does this code work fine for you?
Steema.TeeChart.Styles.Line num;
ScrollPager tool;
num = new Steema.TeeChart.Styles.Line();
tChart1.Series.Add(num);
num.FillSampleValues();
tool = new ScrollPager(tChart1.Chart);
tool.Series = num;
tChart1.Click +=tChart1_Click;
tChart1.Resize += tChart1_Resize;
void tChart1_Click(object sender, EventArgs e)
tChart1.Tools.Remove(tool);
if (tool != null)
tool.Series = num;
It runs for me too, but I I put the " tChart1.Tools.Remove(tool);" in the event of a button and not in the _click event it doesn't run
Hi wakeup,
Code below works fine for me here. Can you please attach a simple example project we can run "as-is" and let us know the exact steps we should follow to reproduce the problem here?
ScrollPager tool;
button1.Dock = DockStyle.Bottom;
tool.Series = num;
if (tool != null)
tool.Series = num;
http://193.145.251.126/pnp/files/DYjQEI ... Scroll.zip
Try this example, press button1 and then button2
Hi wakeup,
Thanks for the project. You have 2 options for this to work:
1. Dispose the tool after you remove it:
2. Use Remove instead of RemoveAt:
tChart1.Tools.RemoveAt(0);
tool.Dispose();
Now it runs. Thanks a lot!
