TeeChart Pro 2013 Help installation problem
andreag0
Post by andreag0 » Fri Dec 20, 2013 1:20 pm
Dear All,
how I can remove correctly from RAD Studio XE5 the TheeChart Standard Help
and install the new TeeChart Pro Help?
I tried already with batch "H2_RegTeeChart.bat" included into
TeeChart Pro installation but it work only partly,
I mean in Help Contents section I still see TeeChart 2013 Standard instead
of Pro.
Thank you.
Andrea Giaquinto
Re: TeeChart Pro 2013 Help installation problem
Post by Yeray » Mon Dec 23, 2013 4:10 pm
Hi Andrea,
Thanks for reporting the bug, it seems there's an omission of an ini file from the help folder.
I attach the missing file here.
TeeChartVCLFMX2013H2Reg.zip
(660 Bytes) Downloaded 301 times
Please copy it into the "Docs\RAD Studio" folder where you ran the "H2_RegTeeChart.bat" replacing the existing ini file. Then, run "H2_RegTeeChart.bat" again.
