Histogram even number bin size
bdw
Post by bdw » Wed Jan 29, 2014 9:08 pm
I have a histogram where I want to always have even numbered bin sizes regardless of the data added to the graph.
For example 4 bins with a range of 0 - 10, 10-20, 20-30, and 30-40.
Is it possible to set these bin boundaries with the Histogram function or would it be easier for me to roll my own ?
Re: Histogram even number bin size
Post by Yeray » Thu Jan 30, 2014 2:22 pm
Do you mean a THistogramSeries or a THistogramFunction?
bdw
Post by bdw » Thu Jan 30, 2014 8:46 pm
Yes I'm currently using the THistogramFunction for this particular graph.
Basically the graphing works correctly if the data distribution has something in all the bins. If say there is no data in the 30-40 range and your bin range is 4 you get say 29 as your max you get 29 / 4 as your bin ranges rather than an even range.
I haven't tried but just typing the question made me think about it, I probably should just change the x-axis scale from auto and set it manually. Maybe its a case of me needing more sleep...
bdw
Post by bdw » Thu Jan 30, 2014 9:06 pm
In thinking some more, this will solve the x-axis numbering but won't effect the legend etc which uses the bin size and maximum number to calculate the percentages.
So I guess what I'm saying for the 30-40 band I'd want the legend to say 0%.
Maybe a fixed size x-axis will do this, I'll have to try.
Post by Yeray » Tue Feb 04, 2014 9:29 am
I'm not sure to understand what's the exact situation. If you still find problems with it, it would be helpful if you could arrange a simple example project we can run as-is to reproduce the situation here.
