TeeChart Labels and Grids
Obelix
Post by Obelix » Fri Oct 22, 2004 1:57 pm
Hi folks,
is it possible to show the grid lines of the bottom,left, ... axis and to hide the labels of the axis at the same time?
-> I have 2 different charts, one chart adjected on top of the other and there should be only one bottom axis visible (the one of the lower chart). Any ideas?
Tia and greetings from Obelix :?
Post by Pep » Fri Oct 22, 2004 3:10 pm
Yes, you can do this using the following code :
        series1.FillSampleValues(10);
        chart1.BottomAxis.MinorTicks.visible := False;
        chart1.BottomAxis.Ticks.Visible:= False;
    procedure TForm1.Chart1GetAxisLabel(Sender: TChartAxis;
        Series: TChartSeries; ValueIndex: Integer; var LabelText: String);
        if Sender = Chart1.BottomAxis then
            Labeltext := ' ';
    end.
Obelix
Changing labels at runtime
Post by Obelix » Wed Oct 27, 2004 12:48 pm
Thanks, it's working very good,
but is it also possible to change the color/font and text
for some of the labels?
Assume you have a gantt series within your chart and you want to display the labels of some of your gantt items in a special color/font style (ie. saturday and sunday in red, style to bold)... and only when it's possible, to show weeknames instead of the date on the labels.
Any tips and tricks avaiable?
Tia Obelix
BTW: Mouse scrolling only works for me, you placed an enabled TWinControl on the chart :(
Marjan
Post by Marjan » Wed Oct 27, 2004 2:36 pm
Hi.
Yes, sure, it can be done. The feature is demonstrated in TeeChart demo. Especially, check the following example:
"All Features -> Axes -> Labels -> Custom Labels"
Alternatively, you can also use chart OnGetAxisLabel event to customize individual axis label font properties. Here is an example:
procedure TAxisLabelsFormat.Chart1GetAxisLabel(Sender: TChartAxis;
var Num : Double;
  Num:=StrToFloat(LabelText);
  // if value > 300, color it red, otherwise blue
  if Sender=Chart1.Axes.Left then
    if Num>300 then Sender.LabelsFont.Color:=clRed
               else Sender.LabelsFont.Color:=clBlue;
Similar code, but with different condition (compare axis label value directly with point labels) could also be used in your case.
Marjan Slatinek,
Obelix
Post by Obelix » Thu Oct 28, 2004 7:01 am
That' it! Thanks a lot, works very well and saved me a lot of time :D
