how to do a donut with percentage inside?
tecsidel
Post by tecsidel » Tue Feb 18, 2014 10:30 pm
I have seen a couple of screens you've published, and noticed a dashboard with a donut with percentage in the middle.
http://www.steema.com/uploads/gallery/D ... eChart.png
How to do this with xe5 teechart pro last version?
Also I don't find how to make these percentages with different sizes with the map series.
Same question about flat design shown in
http://steema.com/entry/186/New_flat_de ... _products_
Gonzalo
Re: how to do a donut with percentage inside?
Post by Narcís » Thu Feb 20, 2014 9:04 am
Hi Gonzalo,
tecsidel wrote: I have seen a couple of screens you've published, and noticed a dashboard with a donut with percentage in the middle.
To get you started, you can find a similar example here.
tecsidel wrote: Also I don't find how to make these percentages with different sizes with the map series.
We will post examples for your other requests as soon as possible.
Post by Pep » Thu Feb 20, 2014 11:45 am
Hi Gonzalo,
The three examples can be easily done, all of them have been done at design time, by using the Chart Editor. First of all, you have to set the Flat theme for the Chart, and the Android palette, this will make to change the chart aspect considerably.
Then, in the case for the Donut series example, you have to specify the hole percent as desired, and add an Annotation tool, which you can position it wherever you want inside the Chart bounds (for example at the hole center), setting a specific font size and family.
About the Map example, as others I used the Chart editor, with map series, adding some Annotation tools to the Chart, setting its position, and font size for each. Although, this can be make by code, specially the case that the annoation size is suposed to change depending on the data.
About the horizontal bar example, I used the Flat theme again, but this time I used a custom color palette, setting each bar color by my own, and change some Chart aspect properties at design time, like pens, fonts, axis, etc.. I've attached the vcl sample to a this post (almost all done at design time).
horizbar_flat.rar
(2.65 KiB) Downloaded 608 times
