How to add an unfilled bubble to a TBubbleSeries
David
Post by David » Mon Apr 28, 2014 9:18 pm
When adding a bubble to a TBubbleSeries, you specify the color. How can I specify that I want a particular bubble to be unfilled. i.e. the border of of the bubble should be there, but there should be no fill. I want to use this to indicate the value the bubble is supposed to represent is undefined (i.e. NAN). All the rest of the bubbles should be colored like normal.
Re: How to add an unfilled bubble to a TBubbleSeries
Post by Yeray » Tue Apr 29, 2014 8:43 am
Hello David,
You can use null points (clNone color) in conjunction with OnGetPointerStyle as follows:
uses BubbleCh, Series;
var i: Integer;
    tmpColor: TColor;
  Chart1.View3D:=false;
  with Chart1.AddSeries(TBubbleSeries) as TBubbleSeries do
    for i:=0 to 9 do
      if i=5 then
        tmpColor:=clNone
        tmpColor:=clTeeColor;
      AddBubble(i, random*1000, (1000/15.0)+Round(1000/(10+random*15)), '', tmpColor);
    OnGetPointerStyle:=BubbleGetPointerStyle;
function TForm1.BubbleGetPointerStyle(Sender:TChartSeries; ValueIndex:Integer):TSeriesPointerStyle;
  if Sender is TBubbleSeries then
    with Sender as TBubbleSeries do
      if IsNull(ValueIndex) then
        Pointer.Brush.Style:=bsClear
        Pointer.Brush.Color:=Sender.ValueColor[ValueIndex];
      Result:=Pointer.Style;
David
Post by David » Tue Apr 29, 2014 3:59 pm
Thank you. That should work.
