How to add NULL array to series
elmec
Post by elmec » Wed May 07, 2014 4:13 am
Q1:We know that NULL values could be added to series by AddNull() function.
Is there a way to Add a null array to series, something like AddNullArray?
Q2: SetNull() function can be used to set specified point to NULL,
Is there a function to set all the point to NULL?
Re: How to add NULL array to series
Post by Yeray » Wed May 07, 2014 7:40 am
elmec wrote:Q1:We know that NULL values could be added to series by AddNull() function.
AddArray function just loops into the given array and calls the Add() function. If you want an addNullArray, you could create it yourself. Ie:
var i: Integer;
    tmpVal: array of double;
  SetLength(tmpVal, 20);
  for i:=Low(tmpVal) to High(tmpVal) do
    tmpVal[i]:=50+random*100;
  Chart1.AddSeries(TPointSeries);
  AddArrayNull(Chart1[0], tmpVal);
function TForm1.AddArrayNull(const Series: TChartSeries; const Values:array of TChartValue):Integer;
var t : Integer;
  with Series do
    BeginUpdate;
    try
      result:=High(Values)-Low(Values)+1;
      for t:=Low(Values) to High(Values) do
        SetNull(Add(Values[t]));
    finally
      EndUpdate;
elmec wrote:Q2: SetNull() function can be used to set specified point to NULL,
As above, you'll have to loop your array of points. Ie:
  for i:=0 to Count-1 do
    SetNull(i);
