Point Image
Point Image
I need to show a point with attached shape. kindly confirm how can i implement this using teechart.
- Point shape
- 1.png (350 Bytes) Viewed 16051 times
- Guru
Re: Point Image
You can use the image itself in an ImagePoint series, or draw it directly onto the canvas, e.g.amol wrote:I need to show a point with attached shape. kindly confirm how can i implement this using teechart.
ImagePoint point = new ImagePoint(tChart1.Chart);
point.PointImage = Image.FromFile(@"C:\tmp\1.png");
point.Pointer.HorizSize = 30;
point.Pointer.VertSize = 20;
point.FillSampleValues();
tChart1.AfterDraw += tChart1_AfterDraw;
void tChart1_AfterDraw(object sender, Graphics3D g)
g.Draw(Utils.FromLTRB(10, 10, 70, 50), Image.FromFile(@"C:\tmp\1.png"), true);
Re: Point Image
I am not able to give the title of ImagePoint, plz answer this.
- Guru
Re: Point Image
I'm not sure what the problem is here. The following code works as expected, with the series title being correctly displayed in the legend:amol wrote:I am not able to give the title of ImagePoint, plz answer this.
point.PointImage = Image.FromFile(@"D:\tmp\1.png");
point.Title = "My Point";
tChart1.Legend.LegendStyle = LegendStyles.Series;
Re: Point Image
Hi ,
I have taken Point not taken ImagePoint and coded then how can i achieve this using Point. plz suggest.
- Guru
Re: Point Image
I'm sorry, I'm afraid I don't understand your request. Could you please provide some code to show me what you need?amol wrote:Hi ,
Re: Point Image
You have taken ImagePoint point = new ImagePoint(tChart1.Chart) in your example but i have taken Point ps=new Point(). i want to achieve same functionality using Point how can i achieve this?
Re: Point Image
Hello amol,
ImagePoint is the specific series style, which is derived from Points series, to plot images as pointers. If you don't want to use ImagePoint series you can achieve almost the same creating your own custom series, deriving it from Points series and overriding its drawing methods as in the example I posted here: http://www.teechart.net/support/viewtopic.php?t=4309
