cjacoby78
- Newbie
Post
by cjacoby78 » Fri Jun 27, 2014 8:14 pm
Hi all,
I am just doing my first tests with TeeChart in Appmethod 1.14 on the iOS platform. I have the TeeChart source code in my project group and everything compiles just fine.
My idea is to use TGanttSeries to represent an electronic program guide (tv guide) visually - my first tests are quite conclusive but panning/scrolling doesn't quite work correctly.
This is how I configured my TChart:
fChart.LeftAxis.Automatic := false;
fChart.LeftAxis.Minimum := -0.5;
fChart.LeftAxis.Maximum := 5;
fChart.BottomAxis.Automatic := false;
fChart.BottomAxis.Minimum := 0;
fChart.BottomAxis.Maximum := 50;
fChart.AllowZoom := false;
fChart.Panning.Active := True;
fChart.AllowPanning := TPanningMode.pmBoth;
Panning works only once when the app is started and doesn't follow the finger but has an offset. A second attempt doesn't work anymore and the app needs to be restarted for the panning to work again.
Any ideas?
I am using the latest TeeChart 2014 source code for FireMonkey.
Thanks a lot!
CJ
Post
by Pep » Tue Jul 01, 2014 10:42 am
in order to make work the pan/scroll over the chart you have to add the following line of code to your code :
fChart.ScrollMouseButton := TMouseButton.mbLeft;
cjacoby78
- Newbie
Post
by cjacoby78 » Tue Jul 01, 2014 5:56 pm
Thanks!
This is the solution!
One more question though - what's the recommended way to pan/scroll only inside some arbitrary bounds?
Christian
cjacoby78
- Newbie
Post
by cjacoby78 » Tue Jul 01, 2014 8:56 pm
A way I succeeded in doing so, was implementing the onScroll event with this:
if (fChart.BottomAxis.Minimum < 0) then
fChart.BottomAxis.Maximum := fChart.BottomAxis.Minimum + 50;
if (fChart.BottomAxis.Maximum > 70) then
fChart.BottomAxis.Minimum := 20;
fChart.BottomAxis.Maximum := 70;
which then blocks scrolling on the bottom axis to a boundary between 0 and 70.
Post
by Yeray » Wed Jul 02, 2014 10:49 am
cjacoby78 wrote:A way I succeeded in doing so, was implementing the onScroll event with this:
Yes, onScroll event is the way to limit the scroll to a known area.
cjacoby78
- Newbie
Post
by cjacoby78 » Wed Jul 02, 2014 11:35 am
Thanks a lot!
